Almost finished bracing Nr.3 :-) photos. http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=22557 |
Author: | Lars Stahl [ Fri May 29, 2009 3:11 pm ] |
Post subject: | Almost finished bracing Nr.3 :-) photos. |
Ok so I had a bearclaw top that was just screaming Brace me. So I did. Needs some final sanding and cleaning up, but other than that I am done. feel free to give me critique. this is the second I am doing with lattice beneath the main x. the first sounds super so I thought I should make another this way. this top is Bearclaw sitka from alaskan spruce. looks great, but the tone is not as nice as the german I had for my latest but it rings ok, it has a little shorter ring and more "ping" to it than the german. Lars. Attachment: bracing.jpg Attachment: bracingside.jpg Attachment: rosette.jpg
Author: | Alexandru Marian [ Fri May 29, 2009 4:26 pm ] |
Post subject: | Re: Almost finished bracing Nr.3 :-) photos. |
So the Sitka is heavier than the German (as it would be expected). That exact same German (I have some sets from the same tree, they weight about 430Kg/m3) sounds shorter and pingier than a lighter than usual Swiss top (400Kg, slightly off quarter cut making it a little floppy across the grain and bassy sounding) i used on my forth ![]() Other than that, the braces look nice. Although, what thickness is the bridge plate? |
Author: | Lars Stahl [ Fri May 29, 2009 6:09 pm ] |
Thanks Alexandru. The bridgeplates thickness is 3mm. So did you like the wood from German spruce ? . Lars |
Author: | Bill Hodge [ Fri May 29, 2009 10:09 pm ] |
Love it Lars thanks for sharing. Have a great weekend! ![]() |
Author: | Chris Paulick [ Sat May 30, 2009 12:36 am ] |
You sure are busy. You must have the bug. ![]() |
Author: | Lars Stahl [ Sat May 30, 2009 3:40 am ] |
Yes I´ve been biten. ![]() ![]() |
